I recently redecorated the room where my WD 4TB mycloud was along with a lot of other electrical equipment and I stupildy let the power supplies get mixed up.
I have a KTEC Power supply that matches the connector and the output is 12V and 1.5A .
Does anyone know whether this is likely to be the correct Power supply?
that is what the manual says it uses. you also need to verify the polarity, the mycloud and most others have + in the center but not all, it should be marked on the power pack
