Hello there,
Can I plug both units into a 4 sockets powerstrip and still retain the same performance and connection stability?
Those powerstrips have a ON/OFF switch and I generally turn them off at night. Would this be an issue?
Thanx.
Hello there,
Thanx.
Most power strips may not even allow Powerline devices to work at all, I would not try it if I were you…
Unless the power strip has surge suppression or line conditioners, it will probably work fine.
In other words, plain vanilla switched power strips are no issue.
