Power for WD TV
I am considering purchasing a Western Digital WD TV so that I can watch all of my DVD through my TV in my caravan.
My question is can I operate and run the WD TV through the 12volt battery system? I run my TV and Set top box through the battery using a 12volt car cigarette socket connection.
I would like to do that with the WD TV.
If it is possible how can I do it?
Thanks in anticipation for your thoughts.
AussieKev
You have two options; you could purchase a Universal adapter with the correct tip on it.   I have NOT tried that.
What I did was purchase an inexpensive DC to AC inverter at a local shop for like $19US.   Then I just plugged the wall-pack into that.
It worked GREAT.   It was used for about 15 hours that way back in July on a family trip.
