My power sockets are behind a cuboard which I cant move but I have one connected with a figure of 8 connector on the end.
Can I use that to plug into the wd livewire (its correct connector) or do I have to use the supplied power cable???
Don’t blame me if it’s wrong, but I would think yes, as long as the notches and everything are correct, you ought to be able to use a generic cable… There’s nothing magic about the ones supplied with the units.
Assuming a standard extension cord would work since the included power cable doesn’t easily reach any of my outlets?
Not sure, but I would think so. They just advise against using POWER STRIPS, which often have power conditioners, circuit breakers, surge suppressors, etc…
