Power Adapter Problem
I have a WD 5000E035.  It uses a strange (to me) power adapter plug that looks like a pin connection. I have two of these power adapters. When I plug one in, the green light on top of the power adapter just flashes, but does not stay on. When I plug in the second one, the green light stays on for about a second, then just turns off. I’m hoping this is a problem with the adapter and not the HD itself. Any help would be appreciated.
Thanks!
Check Article 1378.
I’m sorry Antikythera I’m new here, and I have the same problem with the exact same model, what’s that “Article 1378” that you’re refering to and where can I find it please?
It is the Answer ID that you can find on the WD Knowledge Base.
Answer ID-1378.
http://wdc.custhelp.com/cgi-bin/wdc.cfg/php/enduser/std_alp.php?p_cats=&p_pv=&p_prods=&p_search_text=1378&p_new_search=1
