The last two times I logged into my cloud. The capacity had no information. What is this m0.files and where should it be located? I looked at the log on the cloud and found the following:
Sep 16 10:38:04 LauralandHardy logger: exit standby after 15432 (since 2015-09-16 06:20:50.994418002 -0400)
Sep 16 10:38:18 LauralandHardy REST_API[2275]: 192.168.10.225 OUTPUT System\Configuration\Controller\FactoryRestore GET SUCCESS
Sep 16 10:38:18 LauralandHardy Zend\Log[27242]: 8192
Sep 16 10:38:19 LauralandHardy REST_API[27243]: 192.168.10.225 OUTPUT DlnaServer\Controller\Database GET SUCCESS
Sep 16 10:38:19 LauralandHardy REST_API[2274]: 192.168.10.225 ORION_LOG DBAccess EXECUTEQUERYWITHDB [ERROR] Failed to get prepared statement for sql: SELECT
SUM(CASE category WHEN ‘1’ THEN IFNULL(size, 0) ELSE 0 END) AS video,
SUM(CASE category WHEN ‘2’ THEN IFNULL(size, 0) ELSE 0 END) AS music,
SUM(CASE category WHEN ‘3’ THEN IFNULL(size, 0) ELSE 0 END) AS photos,
SUM(CASE category WHEN ‘4’ THEN IFNULL(size, 0) ELSE 0 END) AS other
FROM
m0.Files
WHERE
isDeleted = 0 . Error: no such table: m0.Files
FROM
m0.Files
WHERE
Sep 16 10:38:19 LauralandHardy apache2[2274]: exception ‘Exception’ with message ‘Failed to get prepared statement for sql: SELECT
FROM
m0.Files
WHERE
isDeleted = 0 . Error: no such table: m0.Files’ in /var/www/rest-api/api/Db/includes/dbaccess.inc:357
Stack trace:
#0 /var/www/rest-api/api/Storage/src/Storage/Usage/Model/StorageUsage.php(76): DBAccess->executeQueryWithDb(Object(MediaVolsPDO), ‘SELECT\n …’)
#1 /var/www/rest-api/api/Storage/src/Storage/Usage/Controller/StorageUsage.php(91): Storage\Usage\Model\StorageUsage->calculateMediaBreakdown(Array)
#2 /var/www/rest-api/api/Core/src/Core/NasController.php(154): Storage\Usage\Controller\StorageUsage->get(Array, Array, ‘xml’, ‘2.1’)
#3 /var/www/htdocs/api/rest/index.php(20): Core\NasController->exec()
#4 {main}
Sep 16 10:38:23 LauralandHardy REST_API[2275]: 192.168.10.225 OUTPUT Alerts\Controller\Alerts GET SUCCESS
Sep 16 10:47:54 LauralandHardy Zend\Log[19566]: 8192
Sep 16 10:47:54 LauralandHardy REST_API[27242]: 192.168.10.225 OUTPUT System\Configuration\Controller\FactoryRestore GET SUCCESS
Sep 16 10:47:55 LauralandHardy REST_API[28059]: 192.168.10.225 OUTPUT DlnaServer\Controller\Database GET SUCCESS
Sep 16 10:47:57 LauralandHardy REST_API[28061]: 192.168.10.225 ORION_LOG DBAccess EXECUTEQUERYWITHDB [ERROR] Failed to get prepared statement for sql: SELECT
FROM
m0.Files
WHERE
FROM
m0.Files
WHERE
Sep 16 10:47:57 LauralandHardy apache2[28061]: exception ‘Exception’ with message ‘Failed to get prepared statement for sql: SELECT
FROM
m0.Files
WHERE
Stack trace:
#4 {main}
Sep 16 10:48:00 LauralandHardy REST_API[28060]: 192.168.10.225 OUTPUT Alerts\Controller\Alerts GET SUCCESS
