I just installed a new MyNet N900 router, attached to my desktop PC, for use with my WD TV Live media player.
What is the maximum distance that should separate these in my home, both located on the same level? Are there any reception issues with objects that are in between the two units, such as walls, appliances or nearby electrical devices?
What signal strength (number of bars) should I have? Can this be improved? What makes it fluctuate? Will change in signal strenth affect viewing videos, etc.? I am normally at one or two bars. The connection test performed by the media player is always a Pass.
thank you
