PLEASE HELP11111 My Passport ultra 1T wants me to reformat
Something happen one day downloading a program. Then when i restarted the computer it told me to reformat the drive. I have tons of files on this drive. can i get the files another way and then reformat it then? Please help!!!
I believe the partition is corrupted. You can format the drive in order to use it again. This will delete all data from the drive but will also delete the corrupted partition.
If you wish to recover your files then try using a data recovery software before attempting to format the drive.
