hi,can anybody help me…i bought a wd hd tv…the salesperson said that can use a usb broadband to connect to network.just need to adjust the settings…can anybody help me how do I do that?thank you
USB broadband? As in 3G / 4G cellular data? If that’s what you mean, then your salesperson lied to you…
It does support WIFI on USB, as long as you use a supported adapter…
yes is a cellular data…so.they lied…ok…so what is the best way to access the network ?since I am using the usb broadband?
and you mention the wifi usb…what is those supported adaptor then?can you give me the link.thank you
Look here:
If you are getting a USB adapter, make sure that you pay attention to the revision version. If you get a different version, it probably will not work.
Perhaps your Cellphone supports Data Tethering?
If so, then you can use WiFi on the WDTV to tether to your phone.
