Hi i got an WD My cloud…
it was in the cellar since 2015 / i did an update… today…
my wife died and i got stored a lot if Fotos and Videos from us there…
i can log in but i cant access the data files…
guys… i beg u … please help !
thanks
thanks
Hi @Helpme3
Have you checked our knowledge base articles?
(Support for Western Digital Hard Drives | Western Digital)
Have you opened a Support Case?
If not, contact Western Digital Technical Support for assistance.
[Contact Us | Western Digital]
Sounds like the update might’ve caused some data access issues, but since you’re logged in, there’s hope! Hopefully, the files are just hiding somewhere in the cloud, waiting to be unlocked.
hi thx for the answers , i logged in but i dont know how to donwnload the data
for example ich see that there are 172 files in the folder but in the webviewer i dont see a file
please help-… please
Sorry for your loss.
If you can log in but can’t access the files, connect via SSH or a recovery tool.
Also, check if the update changed permissions.
Let me know, happy to help!
i am admin so i think i got access.
how can i connect via ssh ?
Hi @Helpme3,
Sorry for your loss. If you can log in but not see your files, try opening File Explorer, press Win + R, type \\Your-MyCloud-IP
, and hit Enter to check if they show up. If not, log into the My Cloud dashboard and make sure you have the right permissions.
You can also enable SSH in settings and use PuTTY to look for the files. If nothing works, a try using data recovery software which might help. L\
