PRODUCT:
G-DRIVE USB-C
Capacity: 4 TB
Speed: 195/mbs
Ok, in short, I have been editing a project off this harddrive in premiere. I have a MacBook Pro. My Firevault is turned OFF.
I control+clicked on my hard drive icon on my desktop and pressed “encrypt” entered a password and basically it’s been encrypting for over 24 hours.
My question is: Is there any way to stop it? I can’t see the progress through disk utility since I didn’t use firevault so I have no idea what percentage it’s on. Is this normal that it’s taking so long? Any way to check progress?
I’m on such a tight schedule for this edit and I’m so screwed and feel like such an ding dong.
I contacted G-technology and Apple but they really weren’t able to provide any definitive answers.
Thank you so much
