I’ve got my new "My Passport "1GB since last Christmas.
Since Febuary, it suddendly disconnects itself during data-transfer most of the time I try to copy files on (my) PCs. I’ve also tried it on a mac or Linux and there it is the same. (I’ve got Windows7).
Surprisingly, some special files are able to be transferred.
There is no problem to transfer files from computers onto the passport.
Hi there, since the issue is present even on different computer with different systems then if I were you I’d change the cable, test it for errors (I use HD Tune) and then replace it…
06-Quick Test on drive 3 did not complete! Status code = 07 (Failed read test element), Failure Checkpoint = 97 (Unknown Test) SMART self-test did not complete on drive 3!
