Please help!!!
when i try to run transmission daemon
i got this message:
“error while loading shared libraries: libssl.so.1.0.0: ELF load command alignment not page-aligned”
Hopefully an experienced user will be able to assist.
There is nothing to answer? You are silent better.
11156, What exacly you do? Install transmission from my repo or from something else?
I think, its my fault, because i update openssl libs in my repo and, maybe, do something wrong…
I don’t know how to do what you want, but be careful! Update some of the stuff on the My Cloud and it can begin to malfunction. The Dashboard UI usually stops first. Worst case the My Cloud becomes bricked.
