Hi all,
I’ve searched the forums but cannot find a similar thread.
I record television using MediaPortal and 2 Hauppauge HD-PVR devices that record high definition content.
I use the WD TVLiveHub for netflix and to playback movies successfully. But when I play shows recorded by HD-PVR, the playback has issues:
The playback takes 20 seconds to start… slow, but fine.
At almost exactly the 1m30s mark, the audio cuts out and the video continues.
Pausing and resuming does not help
jumping ahead or back does not help.
only starting the playback over again resumes the audio for 1m30s
I thought that the Main@L4.0 profile was supported, but do correct me if I’m mistaken.
Any ideas?
Oh ya, my TVliveHub is using the firmware: 2.07.17
A sample recording has the following media info:
General
Complete name : E:\mptv-e\Family Guy\Family Guy - S09E14 - Tiegs for Two - 2011-09-04_21-00.ts
Format : MPEG-TS
File size : 2.06 GiB
Duration : 29mn 56s
Overall bit rate : 9 861 Kbps
Video
Menu ID : 137 (0x89)
Format : AVC
Format profile : Main@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : 27
Duration : 29mn 56s
Bit rate mode : Variable
Bit rate : 8 921 Kbps
Maximum bit rate : 20.0 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.144
Stream size : 1.87 GiB (90%)
Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics : BT.709-5, BT.1361
Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Audio
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Codec ID : 129
Duration : 29mn 57s
Bit rate mode : Constant
Bit rate : 448 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Delay relative to video : -80ms
Stream size : 96.0 MiB (5%)
