I have a mybook live.
I can map it to a drive letter on my remote PC via wd2go.com, but is there a way to do this so that the map persists when I reboot the PC, I don’t have to remap it?
Many thanks,
PB
Many thanks,
PB
I didn’t try the tool, but a batch command file with the command below should work:
http://www.addictivetips.com/windows-tips/fix-windows-cannot-reconnect-to-network-drives-error/
Thanks - I’m sure it’s a silly question, but how do I find out the right server name, etc, for the NAS back on my home network?
