Anyone else notice this? The audio seems to go ahead of the Video by maybe 100 to 200 ms.
Hi.
I use the pause function to syncronize the audio with the video, because it often happens that the movie starts with the audio and video not syncronized.
There is much work to do on the WDEP firmware…
MARCO
It’s not just MKV it does this on!.
Had a few DivX series go out of sync after pausing, Having to re-pause to get back in sync!.
Still a long way to go!!!
TonyPh you’ve finally found a problem with the WDEP - welcome to the club…
Right there with you! :)
Hi, I have the same problem with sound. It is not synchronized, especially when playing through optical output. I must press pause then play again to synchronize sound with video :(
Me too.
And similar when change language or subtitles…
Sometimes accelerate…
I used do stop. and play again, and click on “continue in the same point”…
