the usb cable connector inside the drive is loose, and I can’t get into the case to fix it. Anyone have any ideas? It’s got a lot of important stuff backed up on it, and the cable won’t read when I plug it in because the connector’s loose.
Thanks for the assist, but since the plug won’t seat and even read the drive, anything to do with recovery won’t do me much good.
What I need to know (it’s been out of warranty for years already, I bought it in 2005), is how to open it. I was sort of able to pry up a corner, but the rest won’t give. I don’t want to break it, but I may have to if there’s no way to pry it open.
