Hello guys …i am new one here … I have a serius problem .When i try to unplug or safe removal a device and especially wd passport essentials , or kingston data traveler , i get this error usb Mass storage device is not working properly.I cant find a solution for this problem …See the picture http://i243.photobucket.com/albums/ff1/fuzzjo/wd.jpg the light of the removable storages are on and i cant safely remove them .Is this a windows bug or this is a problem that i only have .,… First i plug the external drive .The drive work properly without a problem When i finish my work , i go to safely remove from the taskbar .and i have this picture . The external drive still works i hear the sound .I try this with all my external drives (3). In XP i dodnt have that problem .When i was safely remove the external the disk was turn of .No sound , and no light …Is that a problem … Tell me if someone have the same problem … Thank you for the support .
Since there’s been no replies, maybe you should try contacting WD’s Technical Support about this. You can do so either by phone or email.
