after some firmware updates for the ex2 have arrived, I hoped, that WD has changed something about the not working “direct” connections.
It seems: Unfortunately not.
In this context, I tried to clean up the port forwarding settings from my previous tries in the ex2 config.
I have found, that one port forwarding rule seems to be some kind of defective or buggy.
It is a rule with completely empty settings (name, protocol, internal, external ports). Only status is “error”.
It neither cannot be deleted nor the settings can be changed.
Is this a bug?
Firmware is 5.21.104
Regards,
uwzl
