Everytime i try to connect my onedrive it says no account… but when i go to my office365 account everything works fine… my google drive is normaly connected but onedrive does not work
Hi tigarrr,
https://support.wdc.com/support/case.aspx?lang=en
The link below will allow you to call support.
