Hello Logan: I have checked and made sure that the firmware was all updated. And it was…
Firmware Release 2.30.165 (04/05/2017)
Unfortunately there still is an issue. The drive backs up only a percent or two and then stops
I have been in contact with Elephant Drive tech support. Here was their answer to me.
The issue on this matter is not that/if your device is or isn’t running the latest version of the firmware, but that we need WD to release a new firmware so we can release a new version of our software. We can only update the application once a new firmware update is released, because the application runs natively in the NAS and we can’t manually update it.
The current application has some known issues where the backups stall. That said, you will need to be checking your backups in a scheduled basis to make sure that they are running as expected. We are currently not able to fix this known issue because the fix requires the installation of a newer version of ElephantDrive and, as mentioned before, the new version will only be available when WD releases a new firmware update.
Please let me know when there will be a resolve to this issue.
Gib Olson
Graphic Design & Continuity
E: info@cre8ed.ca | Ph: 250.862.2393
Fax: 250.862.2395 | Toll Free: 1.877.862.2398
PLEASE WHEN RESPONDING TO THIS EMAIL, if there are artwork changes requested, ENSURE that the request is sent back to artwork@cre8ed.ca
If you have been corresponding with info@cre8ed.ca for pricing, artwork changes may not be sent to the correct department by simply replying to emails at various stages.
Also please click the link to send us your information
http://www.emailmeform.com/builder/form/5rc165K8ibba2
