Hi My WD LIve will not detecting my seagate external hard drive. It always had, up to this point. The light just flashes. I’ve plugged the HD into my PC works fine. Plugged a smaller flash drive into WD, works find. I have an older WD, tried it on that one, won’t work on that also. Checked fermware updates, all ok. Did factory reset, nothing. What gives.??
Don
