Drive offline mycloudEX2ultra is not accessible. Local doc are available, what am I not doing, it worked prior to upgrade ( bios).
Hi Chucklou,
You should refer below article in this concern.
I followed the link…but how can i update the My Cloud firmware if i cannot access it. ?
Regarding the other procedures to follow are extremely complex…is it possible there are not more easy instructions? these storage disk should be plug and play…!
thanks
