Morning all. Please can some one help me out, i have a media storage PC/HTPC and it has shares to several WDTV Live v2 boxes. I have setup the media library functions where by i can browse by cover work/info etc etc.
I have done all of the above, however it took a very long time and has got alot wrong. Is there an application I can install on the media server (windows 7) that I can use to create the meta/xml data source files that the WDTV creates/reads? This way I can manage and do everything with speed and check its correct and the WDTV’s will just update during there usual scans.
Many thanks in advance.
Simon
