I’m a newbie with WDTV but noticed an issue that’s more a FYI than anything else as I expect it will not be addressed anytime soon.
I have a WDTV running firmware 1.04.17 with a LG 50PX4D-EB, unfortunately sound does not work via the HDMI interface to this specific TV and seems like it never did in previous firmware versions.
I addressed the specific issue by using the audio-out plug to a amp, whilst not ideal it does do the job for now until this is addressed by a firmware fix (i guess) - I’m not hoping or relying on that fact too much
I have performed the following to come to this conclusion:
Tried the past 4 (sorry do not have prior version numbers) firmwares available, none of them work with this particular LG TV and HDMI for sound.
Tried the past 4 (sorry do not have prior version numbers) firmwares available, all fo them work with analogue sound out but no sound with this particular LG TV and HDMI.
Switching between Stereo/Digital in options makes no difference (still no sound) when expecting sound over HDMI
Tried several differently encoded videos to ensure it is not a video issue, sound consistantly works via the analogue audio output vs. expecting it over HDMI
Rebooted the WDTV (serveral times)
Unplugged/replugged in LG TV serveral times
Tried to play music (mp3) and radio stations - all of them has no sound over HDMI with this specific LG TV whilst working with analogue audio out.
Replaced HDMI cables - no change
Whlst the LG TV only has a single HDMI port I tried with and without a digital HDMI switch-box, makes no difference
HDMI port itself is not broken on the LG TV as a PS3, Xbox 360 and a Sky cable-box works perfectly with sound on this TV.
Turned off TV and WDTV turned them on (and in reverse order) - no change with HDMI sound out
Unfortunately do not have a optical audio cable to try out but I expect that to work fine if analogue audio out works ok.
The unit itself is not defective as WDTV works fine with 2 other HDMI tv’s including all 3 sets of HDMI cables I did the above testing with.
If anybody has any other wild ideas on what I could test please let me know - but as I mentioned above, I’m pretty content on that there is a issue interfacing with the HDMI controller for sound on this specific LG TV model and I can live with that even though it’s not ideal.
Regards,
E
