Hi All,
So having an issue with sound with netflix, that have not been able to find a solution to by reading previously posted topics on such.
Fairly consistently, if Netflix is the first thing used after WDTV Live is turned on (also confirmed by using the start app on startup function), there is no sound. To remidy this, Netflix has to be exited, a file chosen from the HDD, played, and then Netflix re-opened. This is happening consistently, on multiple netflix profiles, after hard re-setting the device, from all output types tried (HDMI/optical/stereo), using either HDMI/optical/AV.
To test if it was in fact just the netflix app or not, I set the Netflix app to autostart as the WDTV does, and without fail, there is no sound. Sound returns after playing a file from the HDD.
Firmware is the latest with Grid UI, and the above troubleshooting has been attempted.
Does anyone have any input on this?
Rajat
