Hi Guys,
My name is KB. I am a new member here. I just purchased the latest WD Live TV streamer ( the newest one, latest firmware). I have it hooked up via HDMI to my TV/Receiver, and it is a wired connection.
I can play most movies just fine, so far it has played anything I threw at it. Until 2 days ago. I downloaded Iron Man 2 and it seems no matter what format It Is In, It plays with no sound. The first one I attempted to play was an ISO file. I head this streamer could play that, and it did play the video just fine, but no audio. Anyway, since I wasn’t sure I downloaded a new different copy. This time I downloaded an MP4. The MediaInfo txt is quite large, and I do not know about forum rules on linking, so I will just copy and paste it here:
General
Complete name : \KBSMEDIACENTER\Public\Shared Videos\Movies\Iron Man 2 2010 BRip 720p DXVA\Iron Man 2.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom
File size : 2.19 GiB
Duration : 2h 7mn
Overall bit rate mode : Variable
Overall bit rate : 2 456 Kbps
Encoded date : UTC 2011-11-21 02:17:44
Tagged date : UTC 2011-11-21 02:17:44
Video
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 2h 7mn
Bit rate : 2 133 Kbps
Maximum bit rate : 13.5 Mbps
Width : 1 264 pixels
Height : 544 pixels
Display aspect ratio : 2.35:1
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.129
Stream size : 1.90 GiB (87%)
Writing library : x264 core 119 r2106 07efeb4
Encoding settings : cabac=1 / ref=4 / deblock=1:-1:-1 / analyse=0x3:0x113 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=2133 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=50000 / vbv_bufsize=50000 / nal_hrd=none / ip_ratio=1.40 / aq=1:1.00
Tagged date : UTC 2011-11-21 02:21:05
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Duration : 2h 7mn
Bit rate mode : Variable
Bit rate : 320 Kbps
Maximum bit rate : 333 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Compression mode : Lossy
Stream size : 291 MiB (13%)
Encoded date : UTC 2011-11-21 02:20:49
So is there anything I try to get this to play or am I just crapped out with playing Iron Man 2? I should also mention as well as lack of sound, it played very choppy with the MP4, and I have a wired connection on a 22+mbps home network.
Also, It seems everytime I turn my streamer on, it begins to compile my media library. If I leave it for a while to do so, and come back, and the screen saver is on and I attempt to hit a button the streamer will freeze and I have to hard restart it by unplugging the device. Is this a bug or am I doing something wrong here?
I appreciate any and all help and suggestions, thanks in advance for your help and time.
KB
