Maybe someone can help me with this problem.
It has to do with the WD tv Live.
I have no sound wit this file:
Format : Matroska
File size : 1.09 GiB
Duration : 43mn 4s
Overall bit rate : 3 628 Kbps
Encoded date : UTC 2010-11-17 01:51:14
Writing application : mkvmerge v3.0.0 (‘Hang up your Hang-Ups’) built on Apr 19 2010 11:58:49
Writing library : libebml v0.7.7 + libmatroska v0.8.1
Video
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 7 frames
Format settings, GOP : M=5, N=16
Muxing mode : Container profile=Unknown@4.1
Codec ID : V_MPEG4/ISO/AVC
Duration : 43mn 4s
Bit rate : 3 243 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.147
Stream size : 977 MiB (87%)
Writing library : x264 core 104 r1688 0b36c6d
Encoding settings : cabac=1 / ref=7 / deblock=1:-2:-2 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=4 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=3243 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Language : English
Audio
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Codec ID : A_AC3
Duration : 43mn 4s
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Stream size : 118 MiB (11%)
The original file has also no sound on the WD tv Live.
So i thought i had to remux.
I use MKV toolnix Version MKV gui v4.1.1. but again no sound?
I always use this toolnix version without any problems works fine.
When i play the original and remux version on VLC no problem,very frustrating.
I do know how to remux so that’s not the issue.
I thought i will use the new MKV toolnix version 4.4.0. but my WD tv Live will not accept this?
http://www.macupdate.com/info.php/id/16837/mkvtoolnix
Someone?
