Hi My studio external drive no longer shows any power light or connection to my PC. I have tested the power supply output and it is showing 12.3 volts. Any ideas please
You should follow the steps mentioned in below article to check the issues in your external hard drives:
https://support.wdc.com/knowledgebase/answer.aspx?ID=1164#win
