Dear all,
i have had a wd tv live hub for two years now and about 8 months ago the wd tv photo and wd2go apps on my s3 stopped working. It does not pick up any pictures at all even with a reinstall of the app. I recently purchased a iPad and the same occurs. It does not find any pictures on device tv live.
I have read on the forums that there maybe an issue with firmware version 3. Hot get back to version 2 I cannot do as the firmware links are through the Internet bout I don’t see a browser on the wd tv live. Anyone have any clues as to how Dacian access the photos from an application oriented device, ie. smartphone or Tablet.
Thanks,
greg
In regards to “Rolling Back Firmware” i’m not sure what your problem is
On your PC visit this Link …
http://wdc.custhelp.com/app/answers/detail/a_id/5860/~/how-to-roll-back-the-firmware-on-a-wd-tv-live-hub-media-center-or-wd-tv-live
Download a previous firmware revision … and extract it to a empty thumbdrive … remove thumbdrive from your PC and insert into the front usb port on the Hub … and follow the prompts
Gregarious: Are you sure the photos files are still on the hub’s drive? Have you looked at the hub’s drive via a PC and can you see them? Can you view the photos on the PC? I would check this before changing the firmware.
Can your devices (iPad, S3) stream any video or music from the hub?
