ag201
1
I have WD TV Live Streaming with latest firmware 1.12.14.
For certain video files, I am unable to hear audio. The audio seems to be type MPEG.
I have tried resetting the device but no luck.
50% of my files are like this and I am getting no audio, video is fine.
I am in Melbourne.
Can somebody please help me.
Thx.
richUK
2
Post the media info of a file that does not have audio. Full text.
http://mediainfo.sourceforge.net/en (free but untick some boxes if you don’t want the extra programs)
ag201
3
This is the media info. Any help? Thx
General
Complete name : C:\Share\my.avi
Format : AVI
Format/Info : Audio Video Interleave
File size : 697 MiB
Duration : 2h 56mn
Overall bit rate mode : Variable
Overall bit rate : 553 Kbps
Writing application : VirtualDubMod 1.5.10.2 (build 2540/release)
Writing library : VirtualDubMod build 2540/release
Video
Format : MPEG-4 Visual
Format profile : Advanced Simple@L5
Format settings, BVOP : 1
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 2h 56mn
Bit rate : 463 Kbps
Width : 592 pixels
Height : 240 pixels
Display aspect ratio : 2.467
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.136
Stream size : 583 MiB (84%)
Writing library : XviD 1.2.1 (UTC 2008-12-04)
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Mode : Joint stereo
Mode extension : MS Stereo
Codec ID : 55
Codec ID/Hint : MP3
Duration : 2h 56mn
Bit rate mode : Variable
Bit rate : 80.0 Kbps
Channel(s) : 2 channels
Sampling rate : 32.0 KHz
Stream size : 102 MiB (15%)
Alignment : Aligned on interleaves
Interleave, duration : 36 ms (0.86 video frame)
Interleave, preload duration : 242 ms
Writing library : LAME3.90.
Encoding settings : -m j -V 4 -q 2 -lowpass 13.6 --abr 80
I guess it doesn’t support MP3s (or other audio files) with sampling rate of 32 kHz.
richUK
5
If they are ‘internet downloads’ then sometimes these files are encoded in a strange way which the WD player does not like.
