No more images covers after upgrading, Please help
Hello, This is my first post, so be indulgent with me and my horrible English :wink: My problem: I use WD TV Live with an USB HD. Since I have upgraded to Firmware version 1.03.38_V The pictures I have into music ’ folders named folder.JPG does not show anymore. I have carefully read the documentation and don’t know if there is a particular size they must have with the new Firmware. ? My covers “folder.jpg” are coming from “E-music” store where I have a subscription for many years. First, I have deleted the folder _WD into the root directory, then the HD has been scanned once more. No more luck. Can you help me ? :slight_smile:
I think that was beta firmware…
Hello, I have exactly the same issue. using this firmware, so I revert back to the 1.02.21 version but the problem was not solved. I cannot see any pic embedded into mp3 files with a file named folder.jpg in each folder with less than 70Ko. I have reset to defaults setting the WD Live Plus, then reboot and deleted the content of the _wd folder, then re-scan the drive but no luck… I can see my photos normally , Videos play just fine. There is a bug somehow ?
