I do not have an icon in my system tray and so have been unable to disconnect safely. How do I get an icon?
Try this:
1 - Right click on the task bar and select properties.
2- Select “customize”.
3- Make sure the option is set to “show Icon and notifications”.
Thank you so much. Worked like a charm. Hoped that having that icon would make it possible to safely eject passport, but that problem was not solved. Get message that passport is in use. Any suggestions there?
Make sure the the passport is not being used by any application before trying to eject it. If you still have the same issue then you can turn off the computer and unplug it while the computer is not on.
