I’m facing this problem wherein sometimes the Audio is completely missing (video plays fine) when I play DVD contents on my USB drive connected to my WD LiveTV Plus (bought just 3 months ago) and further connected to my Onkyo 7.1 HT system thru’ HDMI cable (supports HDMI 1.3). This is a random, but quite an annoying behavior! I’m not sure what’s causing the problem! Same content would sometimes play perfectly! I’m not able to consistently reproduce the problem. Also, I’m not sure what the solution is - sometimes, a complete switch-off & restart would work, but not all the times! Does this require any firmware upgrade on my WD Live TV Plus?
Anyone who has found a solution, pls help. Thnx. S
