I’m getting an irratating issue (v3.12.13) in that whenever my Live Hub is left for a few hours and goes in to standby (but not set to power down) it decides to go mute. If I manually restart the device by either cycling the power or using the reset menu option then it will play audio just fine. It’s not consistently doing it either. It’s currently set to output audio over HDMI.
This is usally after watching an MKV file, but loss of audio also affects Netflix too.
Anyone else experienced this?
