I set up my EX2100 two nights ago and it’s getting a power loss each night. I have other devices attached to the same power source and they are experiencing no power loss. It’s happened each night around 3:45 AM. The report from the prior night reads:
Power loss detected
Power loss detected on port 1.
Monday, 2017 March 06, 3:43:06 AM
Code:1022
The timing may be coincidental as I’ve been moving files to the drives and they may just have been finishing the move at about the same time each night. I suspect it my be going into hibernate or some similar automated mode about this time and having issues when it wakes but that’s just a guess.
I have the drives set up in a JBOD Configuration so that they are not backing each other up, but working as one large drive. Whenever the drive resets it goes into a cycle of continually rebooting. The lights go blue, they pause for 1-2 seconds and then everything goes red and the system reboots. It will do this for hours if I let it, never going fulling active.
If I pull one drive, it will boot with the single drive that’s left. When I add the second drive back into the mix it’s fine and the drives register as healthy and it functions perfectly until the next night. It’s almost like, upon a reboot, it doesn’t know which drive to read as the primary and just keeps resetting.
Any help or advice. I’m not a network administrator kind of guy. Just setting this up to store a ton of big files and planning to back it all up to a USB 8 TB drive once the setup is stabilized.
THANK YOU!
