So I wanted to keep all my movies files in /home/garrett/Videos/Movies/ and all of my
TV shows in /home/garrett/Videos/Shows/ so I set up NFS config file /etc/exports to show
/home/garrett/Videos/ *(ro,sync,no_subtree_check)
I read the documentation and NFS and if you share a parrent directory all subdirectories are also shared, but for somereason when I share my Videos directory the TV Live Stream says that therer is no media available for playback when I select my Movies or Shows directory from the TV Live. Any ideas? Thanks
Also, since I have a directory for movies and a directory for Shows I seem to have run into a problem with the TV Live. I don’t want my library to show every movie and every episode of every show all cramed together in one menu. I could use the directory list on the TV Live instead of the Library but if you don’t make something your Library the TV Live won’t fetch the cover art. Any ideas on how to fix this? If not WD will you please fix the firmware. I would also like to be able to keep the cover art and meta data in another directory so that I don’t have to give the TV Live write access to my movie files.
