I was wondering could someone help me. I think MLB is faulty but I just wanted to make sure I’ve tried everything. It has been working fine for the past couple of months ( excluding the slow transfer speeds) I unplugged it and when I connected it to the network again the device could not be found. The device only shows the yellow light and does not go blue or green. I tried to reset the device at the rear holding the button for longer than 4 second and it didn’t reset.
Yes I did shut it down, The only worry I have it when I used to log into it at interval there would be a lot of notification warnings to say drive diconnected etc, I always thought it was odd but considering what has happened there might of been an underlying issue.
Is there anything I can do to fix the OS? I find it odd the reset doesn’t work. Would the files still be safe on the hard drives?
Reset button has only a specific use case: To restore the default passwords and return the network configuration to default. It does nothing else - but it has to be fully booted for the reset button to do anything.
Consult nfodiz’s de-bricking guide for more info on how to try to recover your MBLD.
