My Book Live disconnect from the existing connection after some times , device display the green light but no action.
ive to disconnect the power the reboot the device everytime to active and comes on the network.
Is there any solution to rectify the problem.
You may also try power cycling the router/switch where the MBL is plugged, also try with a different one if available. If the issue recurs you may contact WD for a replacement.
There could be an issue with the IP leased to the drive
try setting up a Fix IP and see if problem stops
You can map the drive once the problem is corrected
