The green light on front of the unit is no longer flashing or lit when there is activity.
Can I correct this with my settings
A moderator will likely move this post to the my book live section…
Does your MBL otherwise work normally?
Yes, everything appears to be in order except the green indicator on the front of the unit
Quite a few people have reported that the LED no longer reproduces all the colors (Red / Blue / Green) or the combination colors (Yellow). It’s a hardware issue, most likely… particularly with older MBLs.
Mine started flaking out over a year ago – never bothered me because I never look at the LEDs.
