Short question. I know you can’t save the setting for audio in Netflix permanently. But is there a way to have it not select the 5.1 audio?
I have a PS3 and it defaults to Stereo, which means I have to set it to 5.1 manually which is fine since I don’t need the 5.1 audio. Now with the WD it defaults to the 5.1 audio in Netflix. That’s not what I want since a) my connection is not that good and 5.1 means more bandwith and b) the audio is out of sync if I use the 5.1 stream.
The WD audio settings are set to stereo but that does nothing for Netflix apparently.
