WDBYMN0000NBK-00
SN [Deleted-Privacy]
Need to use WD TV USB Source without any Network Wired/Wifi
I own 3 WD TV boxes. And all of them work.
But I need to be able to take one with me and have the WD TV box “see” the USB external Harddrive that all works fine when the WD TV box are on a network. But if the WD TV box is not on any network the box will not see the USB harddrives or thumb drives as it seems to lock out all other midia lib access until the box has a wifi or wired network connection.
I believe this is a bug and I need to know how to get around the issue to use the box as a straight video player playing video from the USB only harddrives.
I go on the road or go to checkout HDTV at a store and the WD TV Box will not recognize the USB drives using either USB port connection slot yet these work fine at home once the box finds a network and is connected then the box sees my source USB drive connected to the WD TV Box.
Please call me at [Deleted-Privacy] and or e-mail me at [Deleted-Privacy]
This is a very big deal and really upsets me that you can not run the box to do anything really unless on a network. Why even have the USB
Ports??
Michael Barker
