Can you post the part number for the power supply for the 28TB MyBook Duo? Please. I have the 16TB enclosure but want to upgrade it to the 14TB drives but need the more powerful power supply. Thank you. Ideally someone could post a pic of the power supply they received. THANK YOU in advance.
If you have a 12V 3A power supply adapter. That should be enough to power two 18TB hard drive and the internal PCB mainboard.
I tried that and it shows the message that there is not enough power. The manual also says that would need the 4A 48 watts power supply. Do you have a MyBook Duo with 14TB drives or larger? Thanks.
I have two 18TB drives using 12V-3A. Model WA-36S12U
Do you mean this model, WDBFBE0360JBK-NESN? That model number does not come back for me. I currently have WDBFBE0160JBK-NESN and want to upgrade the hard drives to use my 14TB Red drives. Can you post a pic of your adapter and device? Thank you. I really appreciate your help.
