bump
Hey jlabbe,
Sorry it took so long to get back to you. But no you don’t have to edit the xml, the png file will just be ignored because it doesn’t exist after you change the extension.
As for why the moviesheet isn’t displaying I can’t really say. There could be several reasons for this.
One thing that I have to ask though. When you download my theme and unzipped it, did you extract it to your PC then copy it to the HUB or did you extract the theme directly to the HUB? If you did the later then that has been know to cause some problems.
No I did extract all the files from my download folder > desktop, then transfered over to the hub.
There is always that possiblity that the theme is corrupted, very unlikly it is, but I’ll try a new download.
