Need Help
Can I back up just some folders or some files not everything in my document folder?
I want to use a feature in WD Sync, it dose as visual outlook application, so I can plug this external drive to any computer to use it as my outlook on my pc. How can I use this feature in  wd smartware?
You cannot chose files or folders to back up, or not back up, only categories and maybe extensions.  WD Sync is a program designed to work on our WD Passport drives.  You can’t use it with SmartWare, nor can you set up SmartWare to work like WD Sync.
