Need help with vob files or mp4 show title not transfering to HUB only shows "DVD"
Okay, this type of file is new to me.  Here’s what I’ve got.  I burned several kids shows from my DVR to a dvd.  On the dvd there are a total of 6 shows and only two .bup files and two .iso files.  I’ve tried creating a folder for the shows name and within that created a VIDEO_TS folder and the vob file within that.  From what I’ve read the video should start playing once I select the first folder with the shows name shouldn’t it?  Instead, it just navigates through each folder until I get to the vob file and it starts to play.  BUT…the show is only 1 minute 47 seconds long on the WD player but it is really over 20 minutes…
Any help would be greatly appreciated.
On another note, I tried transfering these to .mp4 which did work, the problem with that was that the shows tite wouldn’t transfer over.  Even though on my computer within the WD player it shows the correct name, on the HUB it only shows DVD.  I cant have a bunch of shows named DVD…
I think is easier if you just convert the files to ISO format.
