Need help with RAW system format!
I think the reason why it turned into RAW system format was because, when my computer was reading
its data, the wire loosen, and the hard disk lose connection to my computer.
WD passport
RAW system
0 bytes
type: Basic
Partition type: MBR
I tried using WD reformat exe, but an error appeared saying It is not compatible due to the small space…
Please help =(
Photobucket Pictures, Images and Photos
Any idea someone =(
Try running TestDisk http://www.cgsecurity.org/wiki/TestDisk and see if it will fix the partition data.
Joe
hmm…already tired this software out, but it cant seems to detect RAW system Format…
