Just purchased the 1.5TB version. When I hook the drive up, it automatically recognizes it as a CD drive and the software works fine, I guess. Problem is, I want to use this as an external drive, I don’t want the software. I plan on using this to store data on it using the ROBOCOPY command. But with the software that is installed on it, there is no hard drive space. I have tried to delete the files from the drive without success.
Any ideas on how I can use this drive as just a regulare external drive without all the bells and whistles??
Thanks in advance.
Wayne
