Hope you all can provide me some assistance and guide me on how to display movie info on the WD TV Hub.
I just purchased the Hub this afternoon! I know how to place the thumbnails using Thumbgen and hve them displayed on the Hub.
Unfortunately I have no clue how to do this for movie info or movie sheet, which ever is easier.
I would greatly appreciate your guidance and steps on how to do this. Please keep in mind I am not that computer savy.
Patiently awaiting some responses.
Fernando
In your hub, browse to the movie you want to add Info to.
Hit the OPTIONS button, and select “GET CONTENT INFO.”
Follow the on-screen prompts.
Easy as pie!
Easy as pie!
Don’t forget that he needs to have his Hub connected to the Internet
Also, without the use of 3rd party tools which I think you can find browsing this forum, it’s gets very tedious if you plan on getting info for a large database as you can only do the movies one at a time and if the file names are not set about in a legible format, it won’t find anything and you need to edit the search string for each file.
