Ninus13
November 27, 2012, 8:27am
1
please support.
there are any issues regarding connections between DLNA certified units in the home network ?
video streaming (mp4 Files) from my mybookliveduo does not start. Message: check network.
But network is fine. viewing pictures and playing mp3 files is working proberly. also access to the public folder is fine.
any ideas ?
Wizer
November 27, 2012, 7:33pm
2
If you can play other files then is not a problem with DLNA
please provide more info as :
What type of device?
Media info, etc
Jmaxim
November 28, 2012, 4:49am
3
Check what files your renderer supports. That is if you are using a Smart TV, verify that the TV supports mp4. You should be able to find this information in the renderer’s manual under specifications.
Ninus13
November 28, 2012, 8:46am
4
hi Wizer.
the divice it’s an panasonic, DMR-BST700.
It is connected to a lokal switched 10/100 ethernet, like my desktop and the mybookliveduo as well.
remarks:
the access via my DMR to my desktop works - video stream starts
the access via my DMR to mybookliveduo - video stream does’nt start (message:check network)
the same file!
conclusion:
from my desktop the file will provided to the DMR and shown on TV
from mybookliveduo not
thanks
ninus13
